Hi All,
Anyone know what the X-Force turbo back exhaust systems that JustJap sell are like?
I noticed that they come with an adjustable silencer... Do they cut power down heaps? I'm assuming you would have to balance it between power and noise...
Any feedback is helpful.
Thanks,
Dave.
https://www.sau.com.au/forums/topic/100895-x-force-exhausts/
Ok lets have a look here.. the x-force exhaust is about $600 excluding a CAT.... another $200 for a half decent CAT and another $100 - $200 for fitting... so approx $1000 for a bolt on cheapish system... Personally you could spend approx the same kind of money you can get an exhaust shop to custom make a 3" mandrel bent exhaust, high quality dump and high-flowing CAT and you can also angle the cannon the way you want it... get 2 years warranty and is MUCH better quality... thats my 2 cents...
If your in the sydney area i will be more then happy to help anyone with getting them a great deal on a custom exhaust system from liverpool exhausts... what have you got to lose?? let me know if your intrested..
Regards,
Sarkis
They are good for the price, see link below for a thread I started on the Xforce systems about a year ago - heaps of info and a long review.
http://www.skylinesaustralia.com/forums/in...topic=54115&hl=
Friend had an X-Force titanium on his S15. Not bad for the money, the welds were a bit shit through and after a couple of times of scraping the ground ripped apart. You get what you pay for I guess though, so overall it was pretty good :P
I have a stainless Xforce exhaust on my s15. Because they are a mass produced item the fit is very average. I am going to get a custom cat back made up that will quieten it down and will fit a whole lot better. I just find it a bit noisy as well.
That said, a friend of mines r33 gtr has a 3.5in xforce from the turbo back which is nice and quiet and the note is perfect along with the fit.
If you are planning on purchasing one to run the silencer in it all the time I would stick with a stock exhaust. The level of back pressure the silencer creates can often be more than a stock exhaust.
An exhaust is only as good as its smallest orifice.
FYI - The custom catback I am having made up is mild steel with a stainless cannon and a very high quality straight though centre muffler (which will do almost all the work. Cannons do very little!). Cost is $600.
Hope that helps.
James
I picked up an Xforce turbo back 3" system for $650 including hi flow cat and stainless cannon. Fitting was about another $200.
The silencer cuts down the noise noticeably, but looks like shite. Without the silencer it was tested at *just* under the legal db limit at the specified rpm.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
    • Nice. I'm looking forward to the updates!
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
