1999 ER34 GT-t
White
94xxx Kms
Manual
Apexi PowerFC
Exedy Sports Ceramic clutch
Blitz Nur Spec V exhaust (with removable silencer), front pipe and Hi flow 3" cat
Blitz LM intercooler kit
K&N panel filter (stock intake box)
Blitz Power meter and SBC iD III boost controller
JVC touchscreen MP3 headunit, Pioneer splits, Clarion rears
Autowatch 3 point immobiliser/alarm with turbo timer
"Skyline" seat covers
Nismo shift Knob
Bass Junky(SAU) Radiator Guide
New Battery
I am the first owner in Australia.
Car has just had its 100000km major service (water pump, belts, all fluids, front pads etc.) Was pushed forward 10000km as I felt it would be better in the long run.
PowerFC was installed and tuned by Bel Garage and pulled 197rwkw at 12psi.
Tires have about 85% tread all round.
Car has 11 months rego.
I have reciepts for all the work that has been done.
Located in Sydney, NSW
I'm looking for $28500 but the price is negotiable.
SOLD
Edited by Binky1970
https://www.sau.com.au/forums/topic/101720-1999-er34-skyline-gt-t/
  • Replies 46
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
