  • Replies 64
Will an RB20DET Power FC work on an RB26DETT or will a Power FC for an RB26DETT work on an RB20DET?
My guess is that it wouldn't - but does anyone know for sure?
i am gonna say a conclusive no. remember for starters that the rb26dett has things like an inlet air temp sensor that the '20 doesn't then take into consideration even the base maps installed inside the power fc. i have got fc edit and there is screens avail for the 26 that the 20 does not have. i dont reckon i can be done
curious as to why you would want to? altho the rb20det version costs more as its an ap engineering model.
i have seen one person who was sure they were going to remap (somehow) their rb25det powerfc to work on the rb20 but i never saw how/what they did. if someone can tell me i can add it to the powerfc faq so its knowledge for all
The air inlet temp sensor is easy to get around providing you have access to a datalogit or even better why not run the temp sensor. :)
The only real issue is the use of one afm when the ecu expects a signal from 2. Easy to get around when you think about it. :P
so you just take that wire out like when you put the FC's into 200sx's how you have to take out wires because there different to silvia's??
You wouldnt be able to drive the car if you put the r33 pfc in although because the r33 tune would be way off?? is this right??
cheers simon
So ah how do we get the GTR PFC to work in a single turbo R32 ie 26 head on RB30 . I don't feel real good about two parallel AFM's in front of the turbo . If one was to get more air ie better duct filter etc the others half of the engine would run lean right ?
Also isn't the R32GTST PFC a modified 32/33 GTR PFC ?
Cheers A .
Edited by discopotato03
well if you were using the rb26 powerfc and used the rb26 head on the rb30 bottom end then it should be a straight plug in and start, providing the loom matches whatever rb26 verison you have, ie r32 loom with bnr32 powerfc.
you could use the apexi safc to split the afm signal's into 1 or split 1 into 2 so you can support either way. the rb26 powerfc expect's two afm signals, so using the safc you could split 1 single afm into two, ie an upstream q45 for open mouthed style or even a q45 in front of the compressor intake (filtered style).
The reason for me doing this would be one of flexibility. I currently have an R32GTS4 (RB20DET). A PFC would be a cool thing to have now, and it may offer me some flexibility in the future if I go with an RB30DET in my current car or buy an R32 GTR.
I have done the reverse, using an RB20DET PowerFC to run an RB30/26.
Use one AFM and parrallel up the ECU inputs. The PFC will see 2 X AFMs both reading exactly the same.
Do the same for the lambda sensors.
Use a standard RB26 air temp sensor mounted in the intercooler pipework before the throttle body.
The speedo readings via the commander/datalogit will be inaccurate due to the different diff ratios.
From memory all of the other sensors are the same.
If you use RB26 standard injectors it will start and run straight up.
:rolleyes: cheers :thumbsup:
two afms, feed into one turbo, which then feed through one inlet tract to the engine. or, 2 afms feed into 2 turbos which then feed into one inlet tract to the engine. there is no difference in the end result here. it's not like 1 afm is the signal for cylinders 1-3 and the other is 4-6. i'm sure there will be a difference in the reading of each afm, but they are just adding the two figures together to get total airflow. it's not running half the engine of each afm, that would be crazy.
you can run a rb25pfc on a rb20 IF you swap injector triggers for clys 5 and 6 and run larger than stock (rb20 stock) injectors.
tested it out on a buddies car and will prove difinitvely when i get my car back together.
This sounds like great info here - saves having to purchase the more expensive AP Engineering version
:rolleyes::thumbsup::thumbsup::thumbsup:
    • I'm thinking that this is such a small part of the problem that you could easily forego the vac pump and just achieve 90% of what you need, which is keeping the gate open when off boost. It's not as if there are not already techniques to keep a gate fully closed under boost. After all, you have boost. Just use a wastegate actuator that will allow you to apply the boost on the appropriate side, just like every external gate out there.
    • Heres another fitment photo. redrilled the pattern to 5x112, and threw my audi´s rims on. had to touch the upper control arms with grinder, because the "sharp corner" was sticking about 2-3mm on the tire path. i have the "fender lip" mostly cut off, otherwise these (too) would contact with it. 20x9.5 ET25 rear    265/30 20x8.5 ET20 front    255/30 they are temporary, and look too big for the chassis. searching for 19s to it.
    • From experience, it will come back to bite you haha.
    • Background: my BMW 225i hatchback (rebodied MINI/X1) came with 3x RE003 and 1x Goodyear Asymmetric something. The RE003 roared and slid around, the Goodyear side was quiet and grippy. Definitely my car was thrashed before it got sent to dealers. My brother also got RE003 all round on his old VA WRX STI, I wasn't impressed with them, car was loud so can't comment on noise. Anyway, Hankook stopped making/updating V12 Evo2. So bought S1 Evo3 runflats. Great daily duties tyre and not that harsh ride. Tyre reviews site/youtube rated them as best stopping in the rain and I believe them. Next set, Goodyear Asymmetric 5 non-RFT. It beat PS4 in tests and is like $100 cheaper, so put them on. Great tyre, more grip then S1 Evo3 but a tad noisier as expected, still rocking them. Next set I am looking to go runflats, probably the new Hankook Evo. Although the new Pirelli PZ5 did well in tyrereviews test. Or go Goodyear Asymmetric 6 which was top tyre last year. The V12 Evo2 on my gen5 Liberty GT wagon did great in cold condition (drove to snowy mountains for a day so my husky can feel his ancestor's roots). Super impressive performance for $120 each lol. Never skimp on tyres, brakes, suspension. There's old pics of my R31's crappy random brake pads bending in the caliper at Oran Park track day somewhere around here. Anyway, my 2 cents.
