hey everyone
heres a list of parts for sale
complete r33 RB25DET engine, with loom, turbo, manifold, gearbox ect OFFERS
xtreme puk clutch, with rb25 flywheel
series 1 headlights $120
series 2 tail lights $ offers
full r33 series 1 interior . good condition $ 500
R33 silver doors - $150 each
R33 series 2 front bar with bottom lip- $ 300- incc black side skirts
r33 5 spoke rims , no tyres ( wll there are but no good) $ 250 painted grey
bonnet latch opener - $ 30
Air conditioning system $ 80
Climate control $ 200
electric window motors , regulators, switches ect, $ 200
Hicas system good working order - $200
Hard shocks with lowered springs aparently tien's $300
good lsd - possibly mechanical?? with rear cradle $ 550
boot lid wioth spoiner ( not gtr) $ 150 silver in colour
front brakes, 4 pot , good condition with lines and rotors and calipers , pads averidge $ 300
rear brakes , black with nissan on them $ 150
brake booster and master cyl, $ 100
rb 25 gearbox conversion , everything you need , consoles ect.
3.5" exhaust fropn dump to diff, $ 70
dashboard no cracks ect including instrument cluster ( 70,00 kms on clock) $ 150
rad support ( small front cut ) $ 300 coond copndition
series 1 grill, $60
folding mirrors $ 100 silver in colour god condition
all other parets avalable
holla and ill post them ecod
cheers :D
https://www.sau.com.au/forums/topic/115509-r33-parts-lots-of-them/
Also interested in the brake setup
Just need to confirm if I am doing a 4 to 5 stud conversion, do i need the brake booster & master cylinder? Also what dimensions are the front and rear rotors? Front (296mmx30mm) and Rear (297mmx18mm) ?????
DO NOT TRUST THIS GUY!!!!
I had organised a deal with the above items a week ago. had it all sorted and he sold them to someone else. HOW F**CKING RUDE!
and now hes put them for sale, maybe he will take ur money, then tell u he sold them already.
Just look around and deal with someone trustworthy!
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
