Group Buy: Goodridge Braided Brake Lines
We are holding a group buy for Goodridge braided brake hose kits.
We have enough people do go ahead with this group buy - if yuou want to be included please make payment before August 4th to make sure you are included.
All kits are $299 each+ $10 Express Postage.
Delivery would take approx 7 days from the cut off date + 1-2 days for AusPost Express post.
These are genuine Goodridge kits which come with all necessary components to install.
They made in Goodridge’s UK factory.
These kits have a life time warranty and are ISO9002, TUC and TOT (UK equivalent to Vic roads) approved.
Goodridge stainless braided brake lines are ADR APPROVED, meeting the requirements of D.O.T. and T.U.V. making them street legal for use on any road in the world.
Pictures here: JustSR.com - Goodridge Brake Hose kits
Why use braided brake hose kits?
Whey eliminate sponginess under heavy braking
Increase braking efficiently
And are abrasion and corrosion resistant
They come with full instructions for install.
Available to suit:
180sx
Silvia
S14
S14a
S15
R32 GTR
R33 GTR
300zx Z32
GTiR
RX3
Want them for another car? Ask and we will find out.... :wave:
If your intersted you need to comfirm your inclusion with me and have paid by the cut off date August 4th.
Please email or pm me with any questions.
Thanks!
Greg
PS also just landed more Bosch 040s, still only $230 each!
Edited by shy180
Guest
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
