Hi guys,
I've Just recently did a manual conversion on my 1998 r34 sedan gt-t and it was a success. It took me a while to research on all the parts needed but the end result was excellent.
Now obviously if i used all r34 gtt manual parts in my car, it would most likely fit without knowing that you dont need to HACK up stuff, but i had a r33 gearbox. With not many people knowing what is EXACTLY done when using a r33 gb, i have taken this opportunity to basically document everything ive done.(not much write up of swapping the gearbox over, but the pics will surely help ).
First off here is a list of all the parts needed, including pics.
-r33 manual gearbox(mine came from a series 2, no difference to series 1, just newer)
PRICE: $1100-$1800
Make sure its a complete gearbox. Just so you dont need to hunt around for bits and peices
-r33 or r34 manual tailshaft(front part of the tailshaft)
PRICE: $100 from forum
This part was my biggest concern. I just bought a r33 manaual tailshaft and i was told that i needed to modify it to fit an r34(wheelbase length of r34 is shorter) After many sleepless nights thinking what should i do..Should i modify my r34 auto tailshaft to fit the r33 yoke on?( that means the car will have to be off the road for a while so it can be measured up) Or should i modify the r33 manual tailshaft to suit the length of an r34( car will be also off the road to get the exact cut up measurement. So nearing the day of my conversion i decided to go to JustJap. Asked if they had a r34 manual tailshaft, luck hit me and they did. So i purchased it, went home and put the two manual tailshafts side by side. Now i found out that the front part of the r33 and r34 tailshaft is EXACTLY the same length!. That was good news so off back to JustJap to get my refund.
After hearing people and workshops saying i need to MODIFY/HACK the tailshaft to suit, i now can conclude that front part of r33 tailshaft WILL fit in a r34. NO MODS, JUST A SWAP OVER.
(comparing (starting from the top) manual r34, r33 and auto r34 tailshaft)
(the rear part of the r33 tailshaft is longer than the r34)
(yokes are the same for the manual r34 and r33, the auto tailshaft is smaller)
(comparing length of r33/r34 manual and r34 auto tailshaft)
( Auto and manual front part of the tailshaft are interchangable)
-clutch kit for a r33
PRICE:$450 on Forum
This is a 5 puk button exedy clutch with Daikin Pressure plate recently purchased from C&B. Rated at 300kw
(the bearing that is supplied with the clutch kit)
-RB manual flywheel with 6 bolts (All RB manual flywheels should fit, in my case, i got a r34 one)
PRICE: $125 from forum
Here is the flywheel when i got it
And here it is when it got machined
bolts
-manual spigot bush
PRICE: $20 From NISSAN
I used an 1996 r33 gtst manual Vin number to get the spigot bush, but all spigot bush should be the same for RBs, well i know the RB25DET's are the same.
-clutch Master cyclinder( r33 gtst or r34 gtt will do)
PRICE: $70 second Hand in mint condition from import wrecker
-slave cyclinder with 2 bolts to bolt on to the gearbox(from r33 gtst)
PRICE: $100 from NISSAN for the salve cyclinder itself
-clutch MC to Slave Cyc lines
PRICE: $95 from online trader (Maltech)
(braided lines)
- Pedal assembly
PRICE: $70 for clutch pedal assembly and a trade, manual r33 brake pedal for my auto brake pedal assembly. From a import wrecker.
I used an r33 gtst clutch and brake pedal assembly. If you can grab an r34 clutch and brake pedal assembly, it be better.
-4lts of Gear oil ( i used Motul Gear 300)
PRICE: $29 for 1lt at Autobarn
RB25DET boxes take up around 3.8l to 4l
-brake/Clutch fluid ( i used Castrol response)
Edited by E_Lu-SHuN
  • Like 2
Now If you are planning on doing the conversion with jack stands, then good luck. It will take ages if you are doing this for the first time. I didnt want to do it under the stands so i opted for a hoist.
I also didnt want to pay alot of money for the conversion.
I rang up a workshop and asked how much the conversion was and they quoted me $1500. I didnt feel like paying that much because most of my $$ went to getting all the parts. I decided to do the pedal area myself. I figured that most of the $$ would of went to making holes and alot of cursing due to limited space around the pedal area.
Now i dont have much pics to explaining the process of doing this because i only started to take pics after i did this area.
What tools you need.
-Socket set. size 10,12,14
-phillps screw driver
-different size metal files
-sand paper
-hole saw set
-power drill(cord or cordless will do) and differnt size drill bits
First off undo the cluster surround( 2 screws on the top)
Then remove that surround and undo the cluster itself ( 4 screws)
Remove the cluster, there are 3 plugs connected to it. It may be easier to remove the key hole/steering wheel surround first.
Remove the bottom trim( the one with the coin pocket)
It has one screw on the left side and 2 screws that hold the bonnet lever.
remove all the connectors on it so you can remove the surround.
Now once all those are done, You can see all wiring loom surrounding and blocking you from accessing the firewall area. You have to manouver around it.
To locate where you are going to mount the clutch pedal and clutch master cyclinder is easy. You can see on the heat insulated material, the outlining of the position for the clutch pedal. Remove it just by ripping it and now you can see the firewall. On the firewall, Nissan have made a template for you to clutch so you can fit it in. Remove the heat insulated material in the engine bay where the clutch master cyclinder will go to.
There would be 3 holes.. 2 small holes are for the clutch pedal bolt to go through to the engine bay and the big centre hole for the clutch master cyclinder to go through from engine bay to cabin.
You have to use a power drill and hole saw to do the centre hole. You dont need to cut the hole to EXACT length on the template and DO NOT cut the hole bigger than the template.
The centre hole, from memory is 47mm in diameter. I used a 38mm. i had a 51mm but it will go over the template. You will need to put alot of pressure on the drill so you can make a hole. Once the hole is done, Use a file to make the hole abit bigger. Sand paper the area you just drilled .
With the smaller 2 holes, You can use a drill bit that is closet to the template size .Drill it with force. Make sure you DO NOT use a LONG drill bit, because if you do , you might damage something in the engine bay when the hole is made.
You will need to drop the steering column because it will be in the way for you to drill the top small hole and you will need to remove a section of the air con ductsjust for clearance. To drop it, use a size 14 socket and undo it, there are 4 bolts holding it, 2 at the bottom and two on the top of the steering column.
When the holes are done, put the clutch pedal assembly in. IT should sit nice and easy and put the clutch master cyclinder in too and connect them together. bolt them up. 1 bolt in the cabin and 2 in the engine bay.
( a pic with the clutch pedal in. You do not have to connect the switch that is on the clutch pedal assembly)
Now with the manual brake pedal assembly, Just remove the fork from the brake cyclinder to brake pedal.Then disconnect the brake switch and shift lock swtich ,then undo all 5 bolts .
Put the new brake pedal assembly in. If your using the r33 brake pedal assembly like i did. 4 out of 5 bolts will fit. the one that does not fit is the top bolt. the frame is further away from the hole that connects to the car. You can get a new long stud bolt to reach the hole. In my case i used heaps of cable ties for now and it works. Manual cars dont have a shift lock switch, so you can cable tie it to all the wiring looms because it will not be in use when you do the conversion.
Once all that is done it should look like this
Put all the surrounds back together and connect the cluster back.
To save a little bit extra time. You can remove the auto gear stick and whatever is around it.
Once all that is done You can bring it to a mechanic, What you can realise now that the rest of the work, will be like a clutch change in a manual. Dont let them tell you otherwise. The spigot bush in the auto may be time consuming but it shouldnt take more then 20 min to take out. The wiring is easy if you follow my diagram so dont let them use that excuse to charge that extra $$$
Bleeding the clutch is easy.. extra charge?
changing gear oil is simple
No mods to the gearbox cross member was done. It fitted in EXACTLY
The tailshaft WILL bolt on.
Make sure you have all 9 bolts for the pressure plate to flywheel. If you dont have it then you might want to ask NISSAN for it.
You can remove the speed sensor on the autobox. The connector is next to the plenum. Just follow the wiring and unplug it
All up the conversion from the workshop cost $300 and under 5 hours. That was cheap considering i supplied EVERYTHING but just set the budget to $500 for the conversion, just in case.
Here are a series of pics during the conversion
( undoing the torque convertor 4 bolts)
(Auto GB flywheel)
(We had to cut the spigot bush because greasing it was not working NOTE: Rear main seal was still fine)
( auto box out)
(manual flywheel bolted on. ALL bolts tightened to correct torque settings)
(bearing getting replaced)
(starting from left to right, reverse switch, Neutural Switch, and speedo signal)
(scattered bolts for bellhousing and pressure plate)
( manual gearbox bolts on with the original holes for the gearbox cross member)
Edited by E_Lu-SHuN
You will need these when you get the gearbox ( These are all r33 parts except the gear knob )
(Circlip is in place to hold the gear stick in )
(had to cut peices off so it would go into gear)
( still using the auto surround for now until i find a r34 manual one )
Here is the wiring for the inhibitor and reverse switch. I didnt connect the neutural switch.
that is the connector from the car the wires to work with are the RED(REVERSE), BLACK with PINK(INHIBITOR), and Grey(POWER)
Anyways here is the allocating pins from the auto gearbox
And here is a rough diagram of how to connect it to the manual gearbox. Colour coded
**both brown wires are the same.Doesnt matter which brown goes to what..its the same**
The reverse switch consists of two brown wires(as seen in diagram) . One brown wire from the reverse switch joins together with the inhibitor(BLACK with Pink) and the power(GREY).
The REVERSE wire (red wire from the auto plug) connects onto the remaining brown wire of the reverse switch.
So for the reverse switch, one brown wire connects to the reverse signal(red wire) and the other brown wire joins with the inhibitor and power(3 joint wires).
Hope that is explaining it easy.
The auto ECU will work fine with the gearbox. You will geet a A/T light up on your cluster, but dont worry nothing is wrong.
Hope my tutorial is helpful for all you r34 tiptronic owners wanting to do a conversion with r33 gtst parts.
Glad to help others.
cheers,
Edited by E_Lu-SHuN
  • 2 months later...
any ideal on the size for a r34 sedan tailshaft? would it be the same as the coupe? or would i have to get a r33 sedan tailshaft?
nevermind that msg.. i just realized you did your conversion on a r34 sedan to begin with.
  • 4 weeks later...
it costed about $3000 if you can pick up a cpomplete box for $1200, around there
GODDDDDDDDDDDDDDD why didnt u just buy a manual 34 if u wanted it that badley ffs. That is a crap load of work for little satisfaction. Nether the less good work :sleep:
good tut, thanx for posting it, im not having a go at this conversion at all im stating the diffrance i felt
thought id share my experience
i blew my manual 34s box n couldnt find another manual one for a resonable price anyways so ended up dumping a 33s manual box n swapped the bell housing around..
while i had the 33s box in there it was very very sloppy compared to the 34s, it didnt feel nice at all which made me sell it n get straight cut gears :).
    • Well, the NA RB25 is nothing special in terms of the amount of power it makes stock, nor with any easy mods like extractors & exhaust, opening up the intake tract, etc, etc. And just like any small capacity NA engine, getting lots of power out of them takes a fair bit of money and, depending on how far you go with big cams and high compression and so on, quite grumpy to drive. So, boost is the answer. Many many many of them have had a turbo added. This is easy enough. Same as for any engine. Need the things you need to bolt on the turbo of choice, fuel system and management upgrades, clutch, stronger gearbox ( you do not want to run a boost RB25 through the NA box), diff, brakes, etc, etc, same as you would for most other NA+T things. Some much smaller number have had a supercharger added instead. These are good and cool, but have nowhere near the potential of the turbo route. All the same required upgrades apply. So, potential? Anywhere from not much to quite a lot, depending on how much effort and expense you want to go to. Is there value in the effort and expense? Objectively, no, there is not. If you're gaining enjoyment and don't mind blowing a lot of money on the project, then that's where the value is. Parts? Nissan dealers for some. Many many on-line vendors who do Japanese manufacturer spares (buy buying them from disposals at dealers around the world, direct from manufacturers, increasingly from Chinese knockoffs, etc) and warehousing them in Dubai or similar places. Amayama, Partsouk, etc etc. There are quite a few. Some local to Australia, some local to Europe, some local to the US. You can upgrade literally everything. For an NA, unless you're going to boost it, there's little point going past a nice exhaust, as I said above. After that (well, actually probably even before that) you should concentrate on making it handle the best it can, good brake components, light wheels and tyres, and just make it something to enjoy throwing through the curves. You'll never, ever win any drag races, so it needs to be taken as a nice point-to-point car. Throw in some Recaros or Brides, nice Momo wheel and gearknob, so it's pleasant to be in (because god knows, the inside of an R33 is not a pretty place!!) and away you go.
    • How many $$$ do you have to slip cams to logbook a car that’s not the orginal to the 1990 standard lol
    • Thanks for the update I truly appreciate it. I was trying to figure out the sensors.
    • My son recently purchased a 93 Skyline GTS25 (NA), I am hoping to get some insight as to what potential this car has.  I have auto mechanical experience, and I am capable of working on this vehicle, but I know nothing about it.  Where's the best site to purchase parts (maintenance, repair, upgrades)? What kind of upgrades are available?  Thanks again and I look forward to any information that you all have to offer!   Darrick
