HI All
so i got my new splitfires today, put them in, ran 1.0mm gap, and getting missfire at the usual rpm 4500-6000. Only running 10psi of boost, had no problems wiht old coils at 0.55-0.6mm at the same boost,
SO WHAT THE HELL. The reason i got these is to stop the missfire and increase my gap to increas mid range pull and fuel ecconomy, so gapping down is a bit of a waste of my money.
Is it possible that the earth might be a bit crap or something?
CAN somone advise me ASAP please
Edited by WogsRus
  • Replies 92
It's a series 2 with no ignitor. In regards to bigger problems, what else can it be, could the problem be a CAS sensor or something else.
I am going to regap to 0.8 but this sux, hopefully i can sorgth it out.
I have no errors on the computer, it has been tuned, new pump and so forth, the car did not miss at 0.55 gap, but the coils were shot, i mean i could hardly see the spark.
Sorry should have explained. When i got the car stock it was ok, but soon after i saw some cracks in the coils so i silliconed them up and they ran for a bit and then got worse. SO i gapped the plugs down till they worked wich was 0.55mm.
I am running the copper plugs that everyone gets on here, the BPRS6 things, NGK, you know the ones.
My fuel ecconomy started to suffer as soon as the coild started to fail, so i am trying to fix this by trying biger and better coils with bigger gap.
Thats not the right plug code... you sure thats it?
There are a few that are similar.
If you gap them down and its working, you have a faulty connection somewhere and isnt letting the power through
Find the cyclinder thats misfiring and it will be easier
Well series two with ignitor, did check with MM, and primary is 1.4k ohms, wich is standard for series two, series ones are like .6k ohms.
AFM is clean did that, just finishing the plugs and see how it goes.
BTW i am on my lappy next to the car while working so hence the responces on the run.
OK so
gapped to 0.8mm, still get a slight miss under 3 full load, bugga. I guess there must be something else wrong, not sure what though.
Any ideas. If my engine was getting crappy earth, would that cause problems?
ALSO installed an R32 wastgate actuator, and DAm, doe the car pull much better now.
HOWEVER also noticed with the splitfires, the car idles better, more pull through the midrange (this was before the actuator), and easier starts.
SO all i need to do now i figure out why it might still be missfiring.
I read somwhere that if the CAS is playing up that might cause some issues.
    • Mainly being afraid of breaking something on something i've poured so much money into haha
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
