Hi guys, recently i heard some opinions that the newer versions of the black version avcr has improved solenoids and other stuffs so that the spiking usual is not as often compared to the silver version... but im not sure of its validity.. anyone knows about this? Also, anyone has the black avcr here that are able to tell me if they display other than kgcm2 ?
https://www.sau.com.au/forums/topic/162435-black-version-avcr-improvements/
the solenoid is only a slave, the unit itself was the issue. i was hoping they did more than just change the case color, but no it is just a limited edition same thing but differrent case.
I see.. so i guess there were no improvements made.. Is avcr really that bad ? From what i read, for 12psi it holds very well, just that anything above it tends to spike. As im still running stock turbos, i think 12 psi is sufficient . So is it safe to say an avcr for 12psi is good enough?
i got my car safc tuned along as the avcr (silver) being setup on 12 psi for the run
dyno sheet shows a perfect 12 psi horizontal line no spiking. so i have no dramas with spiking
I wonder if the avcr has any advantage when it is being tuned with the safc compared to other ebc's, as i would have thought it complements it. Thanks for the feedback, i guess 12 psi should be okay then
