Item: Nissan Skyline R33 GTS-T, GTR Kit, TYPE M -1995 2door sports coupe
Item Condition: Perfect condition, stock as a rock. Always garaged & serviced.
Reason for Selling: Having a baby, & need a family 4 door..
Price and Payment Conditions: $13,000
Extra Info:
-87,000kms
-2.5 litre rb25det
-4 wheel steering
-BRAND NEW TYRES
-10MONTHS REGO!!
-Automatic
-Genuine GTR Front spoiler
-Genuine GTR Left/Right indicators
-GTR Rear boot spoiler
-Nizmo front strut brace
-Apexi Ram AIR POD FILTER
-Apexi Turbo Timer, which is:
-Air flow meter
-Volt Meter
-Oxygen Sensor
-Drivers Side Airbag
-SONY cd player with remote
-2.5 INCH EXHAUST, TURBO BACK & 5" CANNON
Contact Details: email: boostn247@hotmail.com for more info, pics or queries, cheers!
Edited by Boostn247
If it had some decent modz, FMIC, Zorst and it was manual i would give you $15k straight up...
Sorry But thats all i can offer...
Guest
    • Unless things that you want to do include reference to time. Simple Boolean logic is only good for digital inputs or analogues that have been thresholded into digitals. But unless you also have a timer function available (which would more ideally be located inside the program, rather than being forced to implement a timer outside the ECU and bring it in as a seperate digital for every time delay you want to implement), then you can't do some of the things that you might want to do. My PLC ladder logics are obviously littered with program blocks, because that's easier than building it all in ladder gates, but the most frequent of those program blocks is a simple timer, because you actually can't otherwise do that in ladder at all.
    • Log voltage. I'm suspecting the alternator. Or even maybe a bad earth somewhere. ie, seeing as it is rev dependent, I am thinking it is alternator dependent.
    • Yeah so N1 and any other larger than factory pump are pretty famous for pumping the sump dry...obviously we don't often get to spend 20 or 30 seconds at high rpm/full noise on the road so I'd still be suspicious that is what is happening here.
    • You are also getting pressure dips on gear shifts. They're just not dipping as far, but they're dipping quite below the amount of oil pressure you should be seeing, for how much RPM drops.   It quite little could be the oil pressure relief valve is starting to stick open a little/is slow to close.
    • Can you log battery voltage, and TPS, and put all four of those into a single image (even as split graphs)?   The oil pressure drops aren't following RPM as such. I'm intrigued if you may have a ground loop between different sensors. With the engine not running, log your sensors and for example cycle the throttle pedal. See if any sensor values flutter or move about. This won't be a perfect test either as the ECU won't be cycling all of its actuators like it would be while running. What EMTRON do you have? Do you have a link to the wiring guide for that ECU?
