this is of great interest to me currently as im yet to choose turbo(s) for my new build.
please no chatter or conversations as to make the thread easier to wade through if it gets as big as the rb25 thread!
all relevant engine mods would be great too.
  • Like 4
https://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/
this one came with the car, unsure of boost but i think its 18psi. Looks like full boost by ~4750rpm.
HKS 2530's and split dumps
Z32 AFMs
Power FC
sard 700cc injectors
full 3.5inch exaust, cat pipe
standard motor and cams
usual support mods.
was retuned at racepace 330kw at the wheels (rear?) at 18psi. Unfortunately that dyno sheet is unavailable.
Edited by SLY33
well i can only give you a baseline atm.
this is:
R32 GTR
stock turbos
stock dumps, fronts, stock IC
3 inch exhaust
cam gears (on stock cams)
14psi boost using trust profec B spec II
Power FC (tuned by Hitman)
Apexi power intake kit
it made 253 rwkw, but i had them fiddle a little bit more for a slightly fatter midrange, ending up with 247. I thought that was pretty good going for just cat back exhaust, pods, 1 bar and a PFC + cam gears. But it's no where near enough these days :D
Hi Sly33,
as you requested results are a little old and the new motor will be fired up very soon
Standard internals for 2 years
GTR R33
Apexi PFC and hand control
Apexi ACVR
Garret turbos 707160-5
Sard 700cc injectors
Bosch Afms (Z32)
Tomei Poncams 260 9.15mm
Tomei adjustable cam wheels
Tomei timing belt
N1 water pump
Custom 3" intake kit
Custom 3 1/2" exhaust (custom 3" dumps)
Rest was std
manifold/fuel pump/reg/intercooler/plenum/fuel rail/head etc etc
This motor is currently being upgraded to forged internals and getting a few other nice bits and pieces
CP Pistons
Pauter Rods
June oil pump
Tomei head gasket kit/block restrictor
Nismo bearings
Custom port work on the head
Oil cooler kit Apexi with relocator and 19 row cooler
G-reddy radiator 48mm
Blitz 102mm intercooler
Hks manifolds (hpc coated)
as you can see alot of work is going into cooling as this is built for track work as well as street.
I will post results in this thread once the motor is up and running and run in
pete :D
ps i have also a r34 gtr vspec i have been working on with similar spec i might be able to post for you SLY33 after the wkd have to wait and see.
R32 GTR
Apexi PFC D-Jetro
Garrett t04Z turbo running 24psi
Apexi 53mm External Gate
HKS Fuel Rail
HKS Fuel Reg
HKS Step II cams 272 272 10.2mm lift ,
HKS Valve Springs ,
HKS Valve Guides.
HKS adjustable cam wheels
Jun Oil Pump
Arias pistons with n1 rings
Pauter Conrods
608rwhp or 454 rwkw's at 24psi on Ultimate 98
Edited by R32-GTS
R32 GTR – just had engine rebuild done with ...
R34 N1s
Tomei adj CAM gears
Apexi PFC
Apexi EBC
Forged Pistons (Weisco)
N1 bearings
ARP rod and stud bolts
HKS style dumps
3” catless exhaust
Head work
N1 Water
N1 Oil
Tomei fuel pump
Tomei head gasket
SX fuel regulator
std injecotrs (bugger)
std FMIC (bugger again)
std AFMs (yes - I know - I know)
currently seeing ~300awkw (~400hp) @ 18psi
will add Tomei poncams + 700cc injectors + Z32 AFMs and aim for a safe 350awkw
Edited by itbmils
R32 GT-R build 11/92 first rego 93
fresh rebuilt RB26DETT from DART automotive 3000km ago
engine:-
tomei poncam 260 260 9.15 cams
tomei sump baffles
OS cam gears
rebuilt with new internals to DART spec (ask Jim )
TRUST extended split dumps
HKS GT-SS turbos
TRUST FMIC
baffled cam covers
APEXi FC
BLITZ SBC spec R
3.5 inch exhaust HKS rear box
splitfire coils
iri-top plugs
700cc SARD injectors
044 in tank
SARD fuel reg
remote filter and oil cooler.... now holding about 7.5 ltrs of oil...
57mm PWR radiator
power steering cooler
HICAS removed
and it goes on...
drive line is stock apart from the Jim Berry clutch, redline fliuds in the Gbox and diff, and transmaxZ in the ATTESSA with Castrol R 10/60 for the engine
fuel is BP ultimate 98
power is at all 4 @ CRD....
Man 342rwkws from just nismo turbos and only 13 psi the post above is running a bit better turbos in the GTSS but was using like 18-20psi to only make about an extra 15-20kws weird.I wouldnt mind seeing the dyno sheet on this one
R32 GTR
Mods :
apexi air pods
3 1/2 in jap exhurst
power fc ( tuned by hitman )
Made 251.7rwkw or 337.5rwhp on about 11psi on a fresh engine
BIG PICS OF DYNO RUNS
with boost:
http://antilag.com/forums/attachment.php?attachmentid=1638
with a/f
http://antilag.com/forums/attachment.php?attachmentid=1639
More to come soon i hope
BRAD
Edited by blk180
1997 R33 GTR - VSpec
K&N filters
Power FC with std AFM - 15 psi
HKS Hi Power Cat back exhaust
De-CAT
Apexi Front pipes
Twin plate clutch
Everything else (power related) standard
Dyno_150605.pdf
Not sure how to post pictures, if u cant c it then let me know how to post.
This set-up was OK for a month or 2 then AFR increased, Power dropped to 340HP and the following were installed :-
Nismo fuel pump
Nismo fuel pressure regulator
Trust fuel rail
SARD 700cc injectors
Now all running fine and back to 360HP.
Why do some dyno runs have KMH on the X-Axis? I find it of very little use, difficult to tell where power is being delivered. Ask your tuners for RPM...
will get the dyno graphs scanned so that I can post here.
stock everything bar M's pods and large front pipes + 3in highflow cat and 3in exhaust = 230rwkw @ 10psi
same as above parts, but with HKS intank pump, GT2530's Xforce dumps = 275rwkw @ 17psi - not DET, safe AFR's (it still wanted more boost!)
yet to fit PFC, Sard 700 inj's, HKS cam gears, bigger AFM's and 3.5in exhaust. shooting for ~ 320rwkw.
oh - all done on a non rebuilt '89 GTR that I have had for near 2 years.
Edited by DAN00H
  • 4 weeks later...
R32 GTR
2x Trust T517Z's with custom Greddy piping
HKS 600cc squirters/Nismo fuel pump
Trust 600X300X100 front mount
HKS cam gears
Tomei 260 cams 9.15mm lift
Z32 80mm Maf's
Power FC
Full CES race 3.5 in dumps/Y pipe/metal cat etc
Hks external oil cooler/relocater kit/braided lines etc
OS Gikon triple plate clutch
OS Gikon "Cross mission" box
Still on bleed valve for boost control---- TurboSmart E-Boost 2 coming
292kw at 4 wheels @ only 16 psi on BP Ultimate/injectors at 70% duty cycle
* Should go 340kw+ at 4 wheels @ 22psi
*OK its not going to make 450rwkw+ like some bigger combo's but the great thing with this combo is its amazing boost properties and drivability-only marginally more lag than stock turbo's
*will attach dyno sheets soon.
Edited by overev1
Back on dyno for cam timing adjustments.Power went from 351rwkw to 368rwkw.
HKS 2530's
Nismo 600cc inj
Power FC
HKS 264/264 cams
HKS ebc
Z32 AFM's
Trust cooler
Stock bottom end
Tomei fuel pump
Edited by m&m
First dyno done on my car about 6 months ago, I was very impressed with the clean power line and the steady 11PSI held all the way up to 293rwhp. Will get a Power FC and get it dynoed again...
1993 R32 GTR
Retuned 28/Mar/2006
120,000kms
3" Mandrel bent zaust
R34 ball bearing turbos
front dump pipe
HKS pods
Power FC D-Jetro
PRofec B-Spec II (0.9bar)
305rwhp
228rwkw
http://img92.imageshack.us/my.php?image=dynosheet26mv.jpg
Retuned 11/Oct/2006
123,000km
**Added
Tomei Cam Gears
Nismo 600cc Injectors
Nismo Timing Belt
Nismo Fuel Pump
Nismo FPR
Nismo 62deg Thermostat
Cooling Pro 3-core Radiator
322rwhp
240rwkw
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
