Updated July 2011
Why this sticky about the A-LSD?
The problem with this has been that there is little technical information on the Active-Limited Slip Differential (A-LSD) even though it is now over a decade later since they were made. There is information about however the information is scattered all over SAU over a dozen threads. The purpose of this sticky is to have all the information in one place to save people time searching all over the place for hours on end.
What is an A-LSD?
For people's information reading this that aren't aware of what an A-LSD is, it's a rare factory option on certain model R33 GTSTs of having a R33 GTR V-Spec diff. The diff is controlled via an ECU in the boot next to the HICAS ECU. The ECU triggers a hydraulic pump that pumps a hydraulic fluid into the diff to lock it up when required. It does this by observing the behaviour of the wheels and when it detects that one wheel has broken traction it will send power to the other wheel to compensate and keep maximum traction. So in theory it is ment to behave like an open wheeled diff all the time and behave like a locked diff when needed. In theory this is great however it doesn't always go according to plan.
The problem is the response time. When a wheel starts losing traction the diff should instantly recognise it and go into action instantly without you even noticing. This would give perfect traction. The thing is this doesn't happen. The single wheel will break loose and in certain situations the diff will take ages to send power to the other wheel - sometimes not at all. This causes very unpredictable "tank slaps" when trying to go straight or when trying to slide.
How do I know if I have an A-LSD?
The way to spot whether a vehicle has an A-LSD is as follows:
Cooling fins on the diff itself (and a large hydraulic line going to it)
Hydraulic pumps and wiring underneath back rear of vehicle
Hydraluic fluid resevoir in boot on right hand side
Two ECU's next to battery in the boot (one is HICAS, the other ALSD)
A-LSD and SLIP wording inside tacho on dash
Resevoir in Boot
The resevoir in the boot holds the hydraulic fluid required by the A-LSD. The original Nissan fluid is called Matic D however it is expensive and hard to get. Instead Castrol Transmax Z can be used due to it being an equivalent fluid.
A-LSD Fluid
The diff itself has "USE LSD OIL ONLY" stamped onto it so something like Castrol LSX90, Motul LSD oil or similar shall be fine. Some people have used non LSD oil it the diffs however I would do what Nissan says.
The following thread showed the main discussions about what fluid to use.
Next we shall go into the problems that arrise with the tricky A-LSD.
Aftermarket ECU Problems
The first problem that arrises with the A-LSD is aftermarket ECU’s are not made with it in mind. This causes the A-LSD to go into instant failure mode as soon as the factory ECU is removed and something aftermarket is put into its place. The A-LSD light on the dash will illuminate to indicate a failure. Luckily this is a fairly simple fix but took a long time to find by some of the people here on SAU.
The following thread shows how to overcome this problem. Basically a TPS signal needs to be rewired to go the the A-LSD ECU in the boot.
Thanks go out to T04GTR, Moanie and PaulR33 for this.
Diff Lock Problems - Bleeding
So now going onto the main problems with the diff, the delay. One main reason that adds to the delay is air being trapped in the lines that the hydraulic fluid flows through. This air needs to be bled - just like in brake lines.
On page 3, PaulR33 wrote a bleeding method for the diff.
The main thing is to use the bleed nipple on the top of the diff, which most people never knew about and the bleed nipple near the pumps.
Diff Lock Problems - Full Control with Aftermarket ECU
Here is my DIY write up on how to get full control of the A-LSD with an aftermarket ECU. This means that you can setup the diff to function the way you want and have it locking up when you choose.
Once again, great thanks to everyone involved in those threads, especially PaulR33 for all his hard work and posts regarding the A-LSD. Hopefully this sticky can continue to be a good information source regarding the A-LSD.
Phi
Edited by PranK
Fixing links
https://www.sau.com.au/forums/topic/268134-r33-gtst-active-lsd-information/
Nah i believe the diff only ever came out on the R33 GTR V-Spec and as a factory option on the R33 GTST Series II's. However that's only because i've never seen/read about one elsewhere.
Feel wise i can only compare it to a normal R33 GTST diff since i've never driven a R33 with a 1.5-way/2-way mechanical diff. To me it feels completely normal, only times it is annoying is when it doesn't lock the wheels properly and single spins one, usually the left one and causes the car to kick out quite badly when coming onto power. It's been doing it more often lately hence why im going to service the fluids.
Ok. Just to add my 2 cents worth to this. I have never seen an ALSD in a series 2. I have seen several in series 1's Including my own.
To correctly bleed the system one must remember there are 2 bleed nipples. One at the pump under the boot and one on top of the diff on the left hand side.
If you look at the lid to the reservoir there is a tube protruding from it when you remove it.
Insert the tube on top of the cap, screw the cap back on and apply compressed air via the tube to bleed the system.
You can gravity bleed the pump nipple first but you must apply air pressure to the system to bleed the diff nipple.Be it because of their age or not i do not know but they require regular bleeding to keep them in top working order. Lack of maintainence renders them a useless single pegger but regular bleeding sees them working damn fine.
They really shine in high speed sweeping corners in conjunction with hicas (Ilove that too).
Once the car reaches its grip level the hicas and alsd work in unison to keep correcting the rear slip.
It can be a pain in the arse to maintain but i have no plans to swap mine out simply because its the best damn diff on the planet when it works correctly. That and the fact that it is a way bigger stronger diff than anything else in the skyline range.
Cheers for that buddy, ill make sure I bleed mine properly. I've got some Motul FF-LSD oil for it and the Castrol Transmax Z oil aswell.
Hmmm i thought it was only the Series II's that had them since all the ones i've read about have been Series II's, but there you go, was the Series I aswell.
Edited by PM-R33
fineline i think you may be the man!!! Ive tried so many things to fix this diff, i was ready to rip it out.. Gave it a bleed using a tyre pump as the pressure source which only managed 14psi.. didnt have much faith in it working..gave the diff nipple a good bleed... took it for a quick spin and it either always lit up 2 wheels nice and evenly or it died in the ass(big laggy turbo)... I'm not going to hold my breathe just yet but i think it may be fixed, its definately performing alot better than it has for a long time. I'll know for sure next time i go for a drift... maybe this should be added to the top post as the method for bleeding?
It's funny ive looked at that lid a 1000 times and never noticed the little hose connecter on top until you mentioned it
Good to hear Jarrod. Just remember, if your experience is anything the same as mine you will need to bleed it regularly to keep it in tip top working order.
Big thanks to Dan at Elite racing developments for putting us on to the pressure bleed technique. It made all the diff. (pun intended)
Thought i would quickly update this.
Changed the fluid in the boot and bled it properly with the nipple underneath the pump and the nipple ontop of the diff a month ago(most annoying position to put a nipple, no wonder people never knew about it). After a couple of days topped it up and checked over it again.
I also wired some LED's into my dash for the ALSD light and SLIP light as mine got covered up with my white faced dials I put in years ago.
My god, what a difference. Diff locks very nicely now and is very controllable in a slide with the slip light coming on when it is supposed to and the ALSD light not coming on to indicate a failure. The car also no longer kicks to the side violentely when coming onto boost in lower gears, holds traction nicely or just lights up both wheels. Very happy with the results :)
I think i will bleed the diff every 5000km when i do all my other services to keep it operating well.
Edited by PM-R33
PLYNX - i wouldn't bother installing one, they are great when they are working properly but can be very troublesome requiring alot of maintence.. they add an extra 30-40kilos at the back end and its a fairly complicated system
has anyone got any ideas to why they work fine for many years then all of a sudden require bleeding every few months? maybe leaking seals or lines? anyone got any ideas? ive had a look at the lines and cant really see much that you could replace..
Hmmm ! Found a complete wiring harness now and Im still thinking of going a head !
Not to concerned about the weight factor. Ive seen the size of these diffs and as I have a fairly heavy duty 25/30 set up ready to go, strength is what Im after. As to the bleeding situation, the industry I work in uses machinery that has a similar oil pumping pressure seal system on them. They have a auto bleeding set up to bleed air out of the seals or they fail. When you hit the start botton the air is automatically bled out for abut 30 second and then it shuts off. Cant see why the same set up wont work on the diff.
Yeah fair enough, but that's making an allready complicated diff even more complicated :blush: Your choice man, i just don't think it is worth all the dramas with what you would have to go to to install it.
as with any other internal combustion engine that liquid cooled, yes you can run it without a thermostat, but your heater will not be very hot and the vehicle will run at a cooler operating temperature so the oxygen sensors will probably take longer to heat up, thereby you may need to start the car 10 minutes before you drive it when it gets below say 40 degrees fahrenheit outside. other than that it should still work fine.
Thanks
Jimmy
  • 3 months later...
  • 2 months later...
I just bought a R33 off ebay. Series 1 94 Model and was pretty happy to see it has A-LSD and still has hicas installed. Also has dual airbags which was a suprise for a series 1. The seller never mentioned any of these things and didnt know anything about A-lsd. My plan is to use the car at queenland raceway for timeattack series so I will be interested to see how the diff performs on the track compared to my 180sx with the stock LSD and no hicas
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
