basically it started when i got my ca tuned again and it got 225kw and on the way home started making tapping nosies at part throttle and lost power, when i got home an hour later it looking like i had done a main bearing. after riding around in GTRseans R32 all of these years i was getting sick of torque of the ca, as a joke i said "why don't i just put a v8 in it." and sean sugested that he's up for a challenge and if i organised the engine and equipment he would help me with the making of engine mounts and all the unforseen things. after a few visits to MRC who is putting a twin turbo VH45 in his R31 and lucky enough had a stock vh45 and auto gear box that had just been put in a 300zx, and doing a few measurements to make sure we fit between the rails i had an engine and gearbox sitting in my garage and a ca18det with no where to go (ps pulling apart and selling)
the following pictures are of sean and me test fitting the v8. we are currently ( by we i mean sean) trying to complete the custom bell housing to suit the 300zx manual gearbox i bought for it.
https://www.sau.com.au/forums/topic/275110-180sx-vh45/
Yep, keep the money rolling in to gets bits and pieces and I'll keep going lol.
Plenty of research done before we got the engine.....youtube, american sites etc.
Also liasing with engineer on rules and regs to keep it fully legal.
Needs extractors bad!
post-12712-1245220788_thumb.jpgpost-12712-1245220824_thumb.jpgpost-12712-1245220881_thumb.jpg
Next things to do will be:
Remove auto bush from crank and fit a spigot bearing.
Fit up a flywheel and clutch and measure up bellhousing.
Chop/Change bellhousing flange to suit v8 bolt hole pattern.
temp fit eng and gearbox to make engine mount brackets/clearancing.
https://www.sau.com.au/forums/topic/275110-180sx-vh45/#findComment-4662127
I'm putting one of these in my Z32 hardtop. Click the link in my sig if you wanna look :sick:
How are you going with the alternator clearance? Most of the US guys have to notch their chassis to get it to clear. Mazworx offer a full conversion kit, gearbox adapter (Z32), mounts for motor and gearbox, extractors (LHD though) and driveshaft. About $2k US.
Here are some piccies for inspiration: GS14Racers from Nico
This is a drifters car in Canada, not bad :D
Quick vid: Clicky
And here is a few of mine for good luck :rofl2:
My mounts, beefy!
I've binned the air con and power steering, just knocked the seals out of the rack and sealed up the old fluid ports. Got a heap of goodies for it, 1.5way diff, Tein's, adjustable everythings, Recaro's, 4 point welded cage etc etc. Also got a truck turbo that should work nicely, just have to mount the alternator up in the V to make it fit.
https://www.sau.com.au/forums/topic/275110-180sx-vh45/#findComment-4667949
I got 2 motors at about $1500 each, they have gone up in price over the last year or so, used to see halfcuts going at $1.5K. I'm using a Z32 5 speed, which go for between $300 and $1200 depending on who you know :) The VH only came with a auto box, and no manual will directly bolt up. I got one of 5 prototype adaptor plates from the states.
https://www.sau.com.au/forums/topic/275110-180sx-vh45/#findComment-4676998
yeah, paid about 2k for mine. using a Z32 gearbox and getting an adapter plate made for it which will be recessed into the gearbox housing so we don't have to run a spacer on flywheel. the engine mounts from the pics above are similar to the ones we are getting from UAS and we will modify them to suit the position we want the engine.
https://www.sau.com.au/forums/topic/275110-180sx-vh45/#findComment-4679275
That's gonna be a nice Z!!
Pulled the bellhousing off the Z32 gearbox and brought it in to get machined down to suit the adapter plate. The gbox will sit flush with the block so there will be no need to space out the spigot bearing, flywheel etc.
Picked up the engine mounts today that we will be using. Got em from UAS.
Pulled the starter motor and aircon compressor off the engine as they will not be used.
Price to get all new chain guides (around 8 in total), seals, waterpump etc is around $1k!!
Thats as far as I have got with it, until I get the bellhousing back anyways.
Engine brackets will be fabricated soon.
Also the block will need to be notched to allow the starter motor nose to clear, see pic of Marks setup.
https://www.sau.com.au/forums/topic/275110-180sx-vh45/#findComment-4691986
  • 4 weeks later...
Noisy.... as in no exhaust?!!! lol
Luck you got em at a reasonable price due to the dollar.
Well, so for now I'm just sorting and cutting out the 180sx ecu wiring, and keeping the power, fuel pump wiring etc.
A problem I've had so far is sourcing VH45DE ecu wiring harness pinout codes, mainly power supply etc.
I worked out a couple but will have to chase the rest sooner or later.
Here's a guide I'm making for the VH45DE:
https://www.sau.com.au/forums/topic/275110-180sx-vh45/#findComment-4742872
Just read your conversion thread and I must say, it's looking great! Takes lots of hours, I know!
The wiring link was very helpful, and I'm sure I have 95% of the wiring covered now!
Here it is!! Glad I played with electronics a lot.
https://www.sau.com.au/forums/topic/275110-180sx-vh45/#findComment-4743061
  GTR-boy said:
wow!
makes me want to put an RB26 in my mums territory!
Lol, I think a turbo xr6 or typhoon engine conversion would suit it better?? :P:P
Still waiting on bellhousing to get machined, so that engine can be lined up to mounts etc, as well as timing chain guides etc to be replaced.
Harmonic balancer was a pain to remove, ie the bolt was tight. So I went to bunnings and bought a 300nm electric rattle gun. Worked a treat!!
Then used a puller, wd40, and it came off sweet.
Cracked open the front timing cover and a cam cover. I must say it was spotless in there, so it's a very clean and well serviced engine.
Pic taken of cams etc, it wasn't touched for the camera lol.
Also pulled intake manifold off. Fair few pipes down there!
Steel plates were cut up and drilled to match the engine mount points. These will be finished once engine is positioned and set in desired spot.
More to come soon....
https://www.sau.com.au/forums/topic/275110-180sx-vh45/#findComment-4768210
Those crank pulleys are done up real tight for a good reason. The oil pump is chain driven from the crank, but the sprocket on the crank is not keyed like the timing chain sprockets. Make use torque it up to the recommended values. I think it's about 270 ft/lb. Apparently it can cause issues if it' done up too tight too, have a search on NICO, heaps of info there.
https://www.sau.com.au/forums/topic/275110-180sx-vh45/#findComment-4768970
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
