1989 mazda mx5
1.6 litre 4 cyl
5 speed manual
150 000
standard viscous lsd
red
hardtop
bilstein shocks on king springs
15 by 8 superlites wrapped with federal rsr
rda slots all round
ebc green stuff pads all round
adr approved braided lines all round
bride zeta driver seat
strut brace
nardi wheel
under body bracings
front lip
roll bar
trust gear knob
that's all i can remember from the top of my head
i've modified the car to handle and left the motor standard, i've looked after the car and serviced it every 5000km with fully syn oil and the interior is in good nick
i don't really want to let it go but i've got a new job which is quite far away and i don't really want to rack on k's and plus it's alot of highway driving so i'll be looking for a bigger 6 cylinder car! and plus my r33 is on the way so i can't really have 2 2 seater cars
price is $9000 ono and open to trades
contact me on 0425660262
i'll upload more pics when i get the chance
https://www.sau.com.au/forums/topic/345201-na6-mx-5/
  • 4 weeks later...
    • I'm guessing you mean something like this size? https://www.supercheapauto.com.au/p/bodyworx-bodyworx-hard-soft-sanding-block---70-x-135mm/594184.html?cgid=SCA01100303#srsltid=AfmBOoq_qZTEe3boann9BaHiB2f59dxJlosWLzCr0zm_weHgUlDX-N5f&start=6 Are they sanded completely flat?
    • Just a standard sanding block size. With the rock chipa they are quite small. I sanded them as you could feel the edges.
    • Say you've just laid all your filler and your about to start sanding, how large is the sanding block your using?  Like a high fill primer? Technically possible but would be a nightmare. Just guessing from the photo, but they look small enough that you might get away with using a 1k spot putty. Normally you'd use something like this on pinholes but with the type of project you're working on I'd give it a go.
    • Omg Brake pedal removal.. FML!!
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
