This engine is 105kgs lighter than the VG30DETT, much lighter rotating mass too. For example the cams are about .5kg lighter each.
Valves are around 2mm bigger reach and has four bolt mains. 93mm bore instead of 86mm
We decided to do this conversion as the VQ is a much more advanced and lighter motor
VQ30 Motor
Fitting motor and checking angles and measurements.
GT28RS turbos with Tial stainless turbine housing mounted east-west rear in engine bay.
Jigging turbos for 6Boost to make custom manifolds.
Custom Manifolds from 6Boost
GTRS Turbo set up with custom manifolds made by 6 BOOST,custom top feed fuel rail, stainless Tial V Band turbine housing.
Dry sump pulley and belt with light weight Kevlar -12 fittings and hoses. 1000psi rated.
Totally striped engine bay, linnished excess welds, panel glue and brackets, then we painted it satin gloss.
New Alternator Bracket
There are more photos on our Motorsports page, Just click on the Project 300zx links.
Also visit us on Facebook
  • Replies 57
TOPIC APPROVED. can't wait to see more johnny. post up all your crazy idea and plans please!! this car is going to be great. the real question is WHEN DO I GET TO DRIVE IT??? don't be tight john. you know the beer baron can handle the zed. i've been a boat captain for years, started in juniors, lazers, tasers, flying ants and moved up to offshore yacht racing. so I think i'm ready for a bit boat like this one.
Yes I have done a lot of sailing to, doesn't qualify you though Rich. She will be a fast boat now. You will have to get in line, after me is John Boston then John Webb and John Bowe, who was here today for a good hour checking the car out. He was very impressed and wants a drive. THe John driven car!!!!!!!!!!Then there is Dave, a mechanic here who has done most of the work, although I think he drives about as good as you, Beer Bitch. Hopefully you won't fit in it either, which is my excuse for fats not to drive it, he he.
Nice work John!!! The slot car has come a long way since I last spoke to you.
Getting very serious now and love the front guards!!! Going to look like a JGTC car....
Keep the updates coming...
Jack
LATEST IMAGES
The Plug is finally finished for the front bar, Painted in 2pack Black. Ready to make the mould, then it will be made in Carbon fibre
This is where we got our design from.
Just installed the motor and Dave is wiring up the Haltech with military spec wires.
I Still dont see any teeth
Looking good John
A bit of bling for you, gold heat shield by DEI, it is supposed to reflect 90% of heat. With the turbo's right back and close to the firewall this should help a lot.
Motor going back in today, ye ha.
Like a rat with a gold tooth. Beat you to it Beer Baron.
http://www.nismo.com.au/images/DSCF0071_000.JPG
http://www.nismo.com.au/images/DSCF0070_000.JPG
so john, tell us more about the engine.
How much have you needed to do to turn it into a viable track engine, just forged internals and a few odds and ends or does the factory vq30 scrub up ok block wise and just needs much the same love as say an rb26 or similiar.
To put it shortly, do you have to spend a mint to make this engine really go?
i already gather that ini your instance your going whole hog.
Hey Mr UAS,,,more power isn't going to fix your problems,,,that "Slot Car" as you call it,,,is what I would call in Slot Car terms a flexicar.
This is your car:-
This is a real Slotcar:-
Cheers cardigan wearer
Neil.
Yes Neil it should give you a run next time we meet. No more power, about the same we suspect, just much lighter, by 105kg. Not big money at all using a stock VQ30DET $1500, then added strong valve springs, dry sump, custom plenum, top feed fuel rail and exhaust manifolds, so it should be efficient. Motor only cost $2000 and has four bolt main, hard annodised pistons, Molly coated skirts, 93mm bore compared to VG30DETT so shorter rods and 9 to 1 comp so should rev. On E85 and 20psi it should easily make an easy 400rwkw with the boost button on the straights. Compared to the VG the VQ has a much lighter rotating mass, the cams are all hollow with narrower lobes and wasted down and all four are about 2kg lighter, a fair bit, alloy buckets with metal shim 39 grams each compared to VG hydraulic 63 grams each, multiplied by 24 adds up to, the cam gears are about half the weight, crank pulley is much lighter although now has a Ross Racing custom balancer. Even the ignition coils are by about 35%. The block being alloy is the biggest weight saving.
The VQ has better port design and stock valves are around 2mm larger.
We do have a spare block with Darton Sleeve kit so can go up to 100mm bore and with VQ35DE crank we have can go 3.8 litre and will use forgies then and bigger turbo;s and make easy 500rwkw.
In addition the VQ30 has another improvement being crank and cam trigger rather than crank angle sensor. More pictures to come, engine and gearbox have just been put in
New dry carbon targa roofs ( no gelcoat, all carbon fibre, Kevlar, Polly core and epoxy resign), now 980 grams each compared to wet carbon 1.55kg previously, so over 1 kg saving off the roof.
Custom alternator bracket to support the rear of alternator, wasted down to save wieght.
Engine now installed into car with Turbos
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
