Hello every1, I have a r34 which the air con is only blowing air softly.
I have read threw forums and have seen fan controller tutorials and filter clean tutorials.
My air con only blows air threw the top vents very softly. The air con fan is turned all the way up and u can hear the fan spinning so the fan controller should b ok.
I think it may be the filter which is blocked and not letting air threw but i am guessing. Can any1 plz confirm this before i pull my dash apart?
Thank u.
https://www.sau.com.au/forums/topic/371082-r34-gtt-air-con-blowing-air-softly/
Hi, yesterday i checked the fuses they were ok and I also cleaned the filters.
I noticed when i put the air con on for the top vents only, i can still feel it coming down the bottom near the vents near your feet. Is there a hose or something that could be disconnected or split?
Air always seems to always be coming out of the bottom vents only. Only very very soft out the top vents.
Even tho i can hear fan spinning, I will check fan speed controller today.
Plz let me kno. thank u
Edited by iwanta34gtr
Hi every1, update.
I just checked the fan controller, and fan - they are both good.
I have also checked my in cabin air sensor (near steering wheel), it was unplugged. I plugged it both cables back in.
I have also tried another climate control unit out of my friends car. Same result.
I also did the air con sensor chek 2 confirm all other sensors are ok. i got result 20 - which means sensors are ok.
It seems that there is either something unplugged with the air con ducting, or what ever controls the air 'mode' (top vents, bottom vents, both top and bottom vents, top vents + window - etc) is not working as i am still getting lots of air out of the bottom vents near my feet, and only very soft air out the top vents.
Anybody have any ideas what to check next or what could cause this? I am out of ideas!
Thank u :)
  • 3 months later...
i have a similar problem to you,
I ran my air con diagnostics and it have issie number 22 coming up which is the in car sensor.
I was wondering if you can provide me with a picture of the location of the sensor so i could check mine out to see if it is a wiring problem or just disconnected
Regards,
Matt
Regards,
Matt
Hey, looks similar to this. Located in drivers side footwell near the clutch pedal. Look towards the centre column and slightly up when your head is down there.
Get someone to change the mode on the air con and see if there is any movement. If so - its not siezed, check that the little silver metal arm is hooked in properly and has not just come loose.
Otherwise, if no movement - push it, it may just be jammed and need a bit of force. If no luck will need to replace the unit.
Good luck.
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
