Sooo, I've done several Group Buys for Sway Bars now, and they've all gone very well, but I haven't really catered for you guys :blush:
Are any of you C34 drivers after Sway Bars or Whiteline alignment parts?
Feel free to post in this thread or send me a PM; I'm happy to help.
Cheers, Dale.
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/
Cheers, Dale.
The 25G is RWD and has no rear bar. What do you suggest?
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5927445
I'm not really clued up as to the differences in the subframes among the different models, so I'll have to defer to the more experienced guys on that. I'm going to have to pay more attention.:blush:
If we can ascertain what subframe it is; I'm sure we can find a bar to suit.:thumbsup:
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5927479
Cheers, Dale.
i could be interested pending prices
my mate bought a 33 that was originally a gts (non turbo but converted in japland with turbo everything except rear way bar) all the mounting points were there under the car and on the lower suspension arms so we bolted a whiteline bar in there
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5927773
Check out the Cusco ones while you're at it - may or may not be more expensive.
Had a quick look at their website - bars are about AU$350 but they don't seem to list Stagea ones so onoly the Sklyline ones known to fit would be of interest. Probably Aussie made ones would be a better bet.
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5927932
Had a quick look at their website - bars are about AU$350 but they don't seem to list Stagea ones so only the Skyline ones known to fit would be of interest. Probably Aussie made ones would be a better bet.
$350? I'll be able to smoke that pricethumbsup.gif Should be around $230-$240ish.
^^ agreed.
can also use R33 GTR swaybar on front
Thanks for the tip; I'll get some prices together.
Cheers, Dale.
Edited by Daleo
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5927992
Ok, prices;
Front AWD;
BNF27Z; 22mm ADJ AWD RRP; $265 Me; $220
Front 2WD ONLY!
BNF24Z; 24mm ADJ 2WD; RRP; $265 Me; $220
BNF24X; 27mm Fixed 2WD; RRP; $265 Me; $220
Rear; 2WD & AWD;
BNR11Z; 20mm ADJ; RRP;$299 Me; $240
BNR11XZ; 22mm ADJ; RRP; $299 Me; $240
BNR11XXZ; 24mm ADJ; RRP; $299 Me; $240
Links;
KLC108; Front Heavy Duty Ball Link; RRP; $180 Me; $120
KLC109; Rear Heavy Duty Ball Link; RRP; $180 Me; $120
Let me know what you think.
Cheers, Dale.
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5928081
I'd be keen for front and rear AWD swaybars, anyone got recommendations for which thickness to go for on the rear one?
I would tend toward the 24mm due to the extra weight in the rear (a lot of glass & steel high up in the body) and this will also tend to reduce understeer.
I'm not really familiar with the handling bias of the C34 but I would imagine it is understeer biased.
Feel free to correct me.
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5928107
Good prices!
Sway bars are the best bang for buck investment in handling. Worthwhile for a stock or modified Stagea. Improves cornering no end and there in NO DOWNSIDE - no harsh ride or other problems.
I have the 24mm solid rear which is a big upgrade on the stock but would not suggest a smaller one.
For the front the SK kit had 24mm made to special order but the 22mm should be ok as there is a tendency to understeer.
NB I painted mine black as even though they are an upgrade with no implications for reduced safety (the opposite in fact) they are considered a "modification" that might incur unwanted attention.
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5928266
Good prices!
Cheers mate; I aim to please!
Best description of the benefit of fitting Sway Bars :thumbsup:
Mine are also powdercoated Black; stealth FTW!
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5928452
Does powdercoating void warranty? I've been enquiring about powdercoating rims and one dude said that it would compromise its structural integrity..
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5928466
i'm pretty sure powder coating ovens wouldn't get anywhere near hot enough to affect the heat treatment of the metal used.
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5928471
    • $53.35 and a double din Pioneer head unit that I have...
    • Put a camera facing your dashboard so you can film the gauges. Head out to a straight but of road, and filming it as you go from a stand still at wide open throttle to as fast as you can/feel comfortable doing. Then film the dash board as you for example accelerate like normal onto a freeway. This will give us an indicator from Speedo of your expectation of slow, and will give us the rpm reading too to see if it's shifting. (Auto still has tacho from memory)
    • Buy yourself the cooling system pressure tester. Being able to pump it up, and have a gauge on it, AND have a cold engine makes it much easier / practical to diagnose. Additionally as the engine isn't running, you can listen for pin hole leaks as well as watching if pressure drops away. In addition, you can pressurise and while doing so, watch all the little rubber hoses. Some fail very brittle, and will just leak, while others can end up very soft and bulge. While a bulging hose isn't necessarily leaking, one of those small ones starting to stretch / expand in a bad way is an indicator that you'll be looking to replace that one soon   Depending on if this is a project car, or you'll be dailying it in the summer months would alter how I'd be most comfortable with driving the car and how I'd replace. If you're planning to use it as a daily, with no backup, I'd pull the engine, and replace all the external oil/water lines in one big swoop. At the same time do the timing belt, water pump, tensioners etc. Do not open the engine at all. We just want to replace all the things that are inexpensive as a single item, but a PITA when they go. By doing the above, you've made the car from a bunch of age related issues more reliable. If it's a project, and you like swearing while trying to reach into dirty hard to reach places to replace a single hose that may or may not be the leaky one. Just replace the leaking/bad ones as they need it. If it's a project and you'd rather swear at the car once and enjoy it as much as possible, then refer to the process I mentioned in how I'd want to do it if it were a daily. However, the approaches above do come down to how much spare pocket change you have. Pulling the engine and dropping over a thousand dollars on parts, may not be practical for you. Oh, if engine outing, I'd replace as many silicon/rubber inlet joiners as possible too.
    • Yeah, they're pretty dumb though...ie; they'll throw a solenoid error if the solenoid is dead, shorted, wiring is open circuit, or even if the driver transistor has failed (they can't self-diagnose much, they can only test inputs/outputs)... but if you wanted to try, I believe it's this protocol....(uses a long pulse indicator with short pulse counter)...
    • Yeah I'll do what I can without taking off any major parts for now. If it becomes clear I won't get far with the engine in the car I'll have to think about the next steps. I am not too stuck on keeping everything 100% OEM, if there is better solutions, like converting most lines to braided with AN adapters, I'd rather do that than buy overpriced new "shit" parts.
