Unless otherwise stated, all items are 732 Nissan Black Metallic.
Item 1: R32GTR Nismo ORIGINAL side skirts - without front guard 'cap' section. Use your standard one; they're the same.
Condition: Very good, but needs repaint. May need to bolt as well as sikaflex onto rear guard
Price: $500.
Postage: No, pick up only inner North, Melbourne
Contact: PM me
Pics: as below.
Item 2: R32GTR Nismo replica bonnet lip, fibreglass
Condition: Excellent, does not need repaint. Attaches via double sided tape and 4 screws.
Price: $120 or offer.
Contact: PM me
Pics: as below.
Item 3: R32GTR original factory side skirts in SILVER.
Condition: Good, but needs repaint.
Contact: PM me
Pics: as below.
Item 4: Factory R32GTR bootlid
Price: $100 or offer.
Contact: PM me
Pics: as below.
Item 5: R32GTR driver's side mirror.
Condition: Very good, does not need repaint. All motors worked when removed.
Price: $50 or offers.
Contact: PM me
Pics: as below.
Hi, I'm very interested in the r32 Gtr n1 Nismo side skirts. I would like to know if there's anything broken/repaired ?? ( other than small scratches )
If you say that everything is ok and there's no major damage with the skirts like ripped screw holes in the plastic , I'll take them .
I can send you payment on the 10th jan via PayPal .
Send me your PayPal address.
Thanks
Gabriel
Mirror SOLD
Nismo skirts PENDING transfer
Roy: if you want to dummy fit them to the side of your thing message me and come over we can hold them up to see if they fit...
Keen to but the prob is of course it means I have to remove the skirts currently one the car, complete with double sided tape etc etc which is a head fark to get back on properly
:thumbsup:
Will be putting the new vents in my Dash when it arrives. Before putting it in the car.:)
Going to be a nightmare pulling my existing one out from what I've heard. A lot of this maybe :rant:
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
