Anyone here using Radium Engineering Oil Catch Can?
Their product is very popular over at FT-86 crowd, and my friend has one and seems very high quality as well.
Also this catch can size looks similar to the Nismo Catch Can style, which is what I want for having a stealthier looking engine bay.
Edited by etang789
https://www.sau.com.au/forums/topic/443367-radium-engineering-oil-catch-can/
Just had a look on their website (radiumauto.com). USD$165 for the single universal as pictured above. 6 fl.oz capacity (175mL?).
They like much better quality than most I've been looking at. I'm seriously tempted. Good find.
Yea you can also get the Competition Catch Can with more capacity but not sure if it can fit where Nismo locate theirs.
Here is an article review
http://www.motoiq.com/MagazineArticles/ID/2449/PageID/4428/Company-Profile--Radium-Engineering.aspx
Edited by etang789
Here is the picture of the Nismo Oil Catch Can which I think is the ideal location for a catch can.
BTW is the RB26 valve cover breather hose size 22mm ? Not sure which fittings to get...
Edited by etang789
  • 4 years later...
Found someone using Radium Engineering Oil Catch Can with RB26 . Not a GTR thou... http://www.superstreetonline.com/features/1802-1984-nissan-skyline-2000-rs-x-dr30-the-last-straw/
Nice and short routing like what I had in mind, just like the Nismo Catch Can.
Edited by etang789
Those things look pretty, but the size makes me question how functional they're likely to be on a high revving, highly boosted RB.  I'd be thinking they will take about 300ml combined and then dump whatever else gets spat out straight into the inlet tract.
They do look nice however.
Generally for motorsport you need to have a catch can which has more volume then your engine displacement, aka 3L ones for Rb's or like 20 of these?
Personally i'd say you can't go past a good custom battery tray replacement one with proper baffles/foam, and a sump breather. Or if you really want something off the shelf then a hioctane style one at least though volume may not be enough
Agreed. Nothing really good off the shelf. Custom is the way to go.
And for CAMS sanctioned motorsport at least, unless it is set up as an oil separator returning to the engine via PCV applied to one rocker breather and the bottom of the can to the other rather than a catch can (So manifold vacuum when off throttle draws oil back in via the breather)  any RB turbo will need at least 3L capacity. I am just about to build a new one for my HR31 and will be making it about 3.5L with an oil return to the sump and a proper filter on the outlet, one track I run at makes the 20DET hoist a lot of oil out. Hard braking followed by a very hard right hander and immediate full power twice in a lap, it spits out up to 500ml in a handful of laps, take it to Phillip Island and it did not put that much in the can over 500KM.
You are not particularly likely to get pinned for it being to small at most  track days but who needs to give a grumpy scrutineer something easy to knock you back for.
I use two of these  with the bottom cut off sitting inside a tank with fuel tank foam.
the base of the tank has a ball valve on it so at the track I can leave it open to drain to sump and all other times it just collects in the tank and I clean it before a track day because it gets sludgy due to moisture over time.
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
